Home > Forums > FLUENT
User Defined Function for convection coefficient
Old   July 8, 2004, 12:28
Default User Defined Function for convection coefficient
ereiss
I am trying to model heat flow from warm water in pipes imbedded in a four inch concrete slab. When I define the boundary conditions for the top of the concrete slab, I can only chose a constant heat transfer coefficient. The heat transfer coefficient is really a function of the temperature difference between the surface temperature of the concrete (which is being solved for by FLUENT) and the free stream temperature (an input for the boundary condition). This is given by; h=1.13(delta T)^0.33. Can anyone tell me in detail how to implement a User Defined Function for the heat transfer coefficient.
Old   July 8, 2004, 16:10
Default Re: User Defined Function for convection coefficie
Ajay
write an execute_at_end function which updates the value of h. (Use face / cell macros to get the temperature ) execute _at_end is executed end of each iteration ( steady case) and at the end of each time step ( unsteady case) -Ajay
Thread Tools
Trackbacks are On
solving passive scalar by user function in AVLFIRE huyp Main CFD Forum 0 September 4, 2008 10:21
User defined function - CO level hari FLUENT 0 October 24, 2007 00:11
User defined function hari FLUENT 0 October 9, 2007 03:24
How to create an user defined function? Cagdas FLUENT 1 September 5, 2007 20:02
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
