July 8, 2004, 01:18 |
external compressible flow
I study a classic case about ramp shock wave,but it diverged after 300 iterations. please help me! my fluent setting as following: Implict couple solver steady operation pressure: 101325pa k-o turbulent model only one inlet(outlet):far-pressure-field£»mach number:5.7£»I=0.01£»length:0.0015m£»gauge pressure=0 computing field: half circle; r=30m courant number:1 second upwind
July 8, 2004, 03:07 |
Re: external compressible flow
It is OK
July 8, 2004, 14:54 |
Try changing far field to pressure outlet
July 8, 2004, 22:42 |
thanks for your help! but there is only flow boundary: far-field in my setting ,according to your advice, I must split it to two boundaries and the one is pressure-oulet,another is ???? I have send my dicrpition of the mesh to your e-mail, please point out your suggestion. thanks!
Compressible Fluid Flow in COMSOL Multiphysics | BBG | COMSOL | 1 | November 19, 2008 14:05 |
Solver for compressible external flow | ryan_m | OpenFOAM Running, Solving & CFD | 3 | April 7, 2008 08:18 |
external flow meshing for a Sedan in pro*am | rave | Siemens | 7 | July 17, 2007 09:48 |
internal flow and external flow ? | Pathway0320 | FLUENT | 1 | November 17, 2006 03:37 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 13:19 |
