Fidap node number
Old   July 11, 2004, 22:07
Default Fidap node number
Young
Could you tell me how to check the node number in the middle of the 3D sturcture ? "nnumbers" gives me only the surface node numbers in the 3D sturcture. Fipost manual described about "plane" and "group" but I don't know how to define "Plane" and/or "group" command. Please let me know.
Old   July 12, 2004, 22:33
Default Re: Fidap node number
mario
Young:
You can use PLANE command. There you choice a point and a vector that define a cut plane.
for example:
PLANE(section, nonbody, pvector)
Then you should indicate the point and the vector in the comand line (bottom and left) in this form:
0 0 0 1 0 0 ( push enter )
the three first numbers are the coordinates of the point (x,y,z), the next three are the direction of the normal vector of the cut plane.
Finally use the command MESH for see the numbers of the nodes on this plane.
MArio
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Problems with mpirun duderino OpenFOAM 17 February 5, 2010 13:00
low turbulent reynold number C-CARE CFX 4 March 12, 2004 06:36
Meshing by specify a type and number of node Jackie CFX 5 April 13, 2003 16:54
