-   -   Floating point error (http://www.cfd-online.com/Forums/fluent/34199-floating-point-error.html)
Chico Mbanu July 14, 2004 13:57
Greetings,
I'm trying to model 1/4 of a D circle with an inlet and outlet. In addition I have two smaller cylinders in the quarter circle that act as tubing for oxygen diffusion. These tubings both have inlets and outlets and the portion that is inside the quarter circle I have given a wall boundary condition so I can add a diffusion coefficient for oxygen. The problem that I am having is that when I run the simulation I get a "floating point error (imprecise)" or a "floating point error (underflow)". I am not sure what this means or how to go around it. If you have any suggestions, it would be greatly appreciated to know of them.
Sincerely,
Chico
Avesta July 15, 2004 08:10
Re: Floating point error
hi i think you should check your mesh grid mesh is very high. your problem solve by selection a low mesh. Avesta
