Floating point error
Old   July 14, 2004, 13:56
Default Floating point error
Chico Mbanu
Greetings,
I am trying to model 1/4 of a D circle with an inlet and outlet. In addition I have two smaller cylinders in the quarter circle that act as tubing for oxygen diffusion. These tubings both have inlets and outlets and the portion that is inside the quarter circle I have given a wall boundary condition so I can add a diffusion coefficient for oxygen. The problem that I am having is that when I run the simulation I get a "floating point error (imprecise)" or a "floating point error (underflow)". I am not sure what this means or how to go around it. If you have any suggestions, it would be greatly appreciated to know of them.
Sincerely,
Chico
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
