Home > Forums > FLUENT
negative values of pressure
Old   July 20, 2004, 06:26
Default negative values of pressure
samir shrivastava
sir, I had used FLUENT to study the pressure drop acroos a sieve of 12 mm dia. Gas and liquid are flowing down through the sieve from different inlet.The boundary conditions used are velocity inlet and pressure outlet. but i am getting negative values of total and static pressure in the contour plots. what does this signify. kindly help as soon as possible. thank you samir
Old   July 21, 2004, 07:26
Default Re: negative values of pressure
mark
These are gauge pressures relative to the operating pressure set in the operating conditions panel (defaults 101325Pa)
Thread Tools
Trackbacks are On
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
High pressure in rhopSonicFoam results in negative pressure shangzung OpenFOAM 0 November 5, 2009 04:24
Negative pressure! Neel CFX 0 March 19, 2008 08:47
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
