Home > Forums > FLUENT
Volume of Fluids at low g situations
Old   July 20, 2004, 12:07
Default Volume of Fluids at low g situations
Jay Butcher
Hi there -
I'm studying flow of fuel around a spherical tank in low gravity situations. For instance a micro-gravity of order 1e^-4 ms^-2 is created as a satellite moves forward, fuel is collected in one half of the fuel tank. The satellite then slows down by retro-firing...the fuel "should" detach from one wall and slam into the opposite wall of the tank.
I'm having problems getting the solution to converge at all if you have any ideas please help!
I'm using the VOF model in Fluent 6.1 and it's a 3d segregated solver.
Kind Regards
Jay
Old   August 4, 2004, 09:52
Default Re: Volume of Fluids at low g situations
Sandeep
Try changing the time to a lower value
Thread Tools
Trackbacks are On
Volume 1 has invalid topology for mapped brick meshing georgewar ANSYS 0 July 24, 2011 16:02
Calculating volume of Phase Pavan FLUENT 2 March 5, 2008 11:04
split volume Kabo FLUENT 1 January 28, 2008 08:08
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
