July 1, 2004, 00:49 |
variable heat transfer coeffitient
How to access heat transfer coeffitient boundary condition? I need to change the value, depending on the surface tempereture.
Thank you. |
July 1, 2004, 14:20 |
Re: variable heat transfer coeffitient
You could use a UDF ( user defined Function ) -Ajay
July 3, 2004, 08:24 |
what is the variable type for the heat transfer coeffitient?
July 5, 2004, 01:54 |
Heat transfer coefficient is defined as q/delta_t
q = heat flux ( w/m2) and delta_t = temperature difference. If you know these two you could find your heat transfer coefficient. |
July 5, 2004, 23:44 |
thank you, I'll try to
July 22, 2004, 10:23 |
Dear Arky
I am also facing the same problem. I want to specify heat transfer coefficient at various points in my domaain. But that option is not directly available in "Read profile" option. Can you please tell me how I can specify the heat transfer coefficient through udf/some other way? Thanks in advance Ravi |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 11:49 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 13:14 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
