July 22, 2004, 13:04 |
SCHEME command to write XY plot to file?
I have a host of models now (some 35 and growing), they share the same geometry and have some minor changes. I would like to compare z-velocity components from all the files. I found that I can use scheme to auto construct several Racks at given points and use them to plot xy-plots. Is there a way to auto save these plots to a file (the data?) within scheme? that would considerably speed up things for me. Thanks Angelo |
July 22, 2004, 16:54 |
Re: SCHEME command to write XY plot to file?
I think you could use Macros
Solve ->execute command->tick command. below you would fine define macro button once you press this it starts to record what you do. go to the xy plot and write out a file define the name with %t at the end and then fluent would replace this with the current time step ex:- vel_pro%t.txt end the macro. return back to the execute command window and put the name of the macro next to the commad which you have ticked. -Ajay |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 15:49 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
