Mixing length turbulence model using
Old   July 23, 2004, 07:37
Default Mixing length turbulence model using
Alex
I try to compare several turbulence model available in Fluent 6 for film cooling task in turbomachinery.
In text commands I've found a Mixing Length turbulence model, but itsn't clear how it does operates. What values of constants are used in it ? Could anyone explain me it ?
Thanks. Sorry for a bad English.
Old   August 5, 2004, 16:18
Default Re: Mixing length turbulence model using
sarah_ron
define/models/viscous/mixing length?
Old   August 6, 2004, 02:19
Alex
Tnank you sarah_ron!
Yes, I use this command sequence. But my question is a what physics constant are used in mixing length model?
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 08:53
Turbulence mixing length value eva Main CFD Forum 1 February 27, 2009 14:19
Sinclair Model + secondary turbulence Yi FLUENT 0 October 26, 2001 13:37
