October 26, 2014, 14:05 |
Natural convection of water
amine
Rep Power: 13 |
I dident get the good results when modeling natural convection into 2D cavity filled with water, using ansys Fluent 6.3, Boussinesq approximation, Laminar flow, steady case Any suggestions to overcome this drawbacks??? Thank you in advance |
October 27, 2014, 01:06 |
Ashutosh
Rep Power: 12 |
Did you specify gravity?
October 27, 2014, 11:18 |
amine
Rep Power: 13 |
October 27, 2014, 11:40 |
Ashutosh
Rep Power: 12 |
Is it possible for you to share your dimensions.. Or else I will try with my own dimensions and will get back to you..
October 27, 2014, 14:38 |
amine
Rep Power: 13 |
Could you please paste your isotherms here ??? and the thermophysical properties for water ???
October 27, 2014, 21:43 |
Ashutosh
Rep Power: 12 |
I am working on it.. I have kept the side walls at hot and cold temperatures each and the top and bottom walls at room temperature.. Are these okay for you or you are using some different boundary conditions?
October 28, 2014, 01:18 |
amine
Rep Power: 13 |
Horizontal walls kept adiabatic, the others are differentially heated,,, but i wanna know the thermophysical properties you're working with!
Thanx |
October 29, 2014, 07:40 |
Ashutosh
Rep Power: 12 |
I have got convergence for your problem. I use water (l) which is in the fluent database under materials. Under density I select boussinesq approximation with density value corresponding to my ref. Temperature. Thermal expansion, I have specified as corresponding to ref temp. Tell me for what values of grashof number are you looking for results?
Natural convection in water | CneSpaulding | STAR-CCM+ | 8 | July 9, 2015 04:18 |
natural convection with stagnation inlet and water? | KyleA&M | STAR-CCM+ | 2 | May 21, 2013 11:48 |
Multiregion Heat Transfer + natural convection (water) with chtMultiRegionFoam | fattychickenrun | OpenFOAM | 5 | October 31, 2011 16:53 |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
How model natural convection in water? | Fiska | FLUENT | 4 | January 28, 2010 03:23 |
