Home > Forums > FLUENT
urgent please heat transfer
Old   July 30, 2004, 14:36
Default urgent please heat transfer
cip_m
hello
i'm heaving some pipes from an engine with wather inside. ok. i'm modelling a heating transfer from the engine to the wather. i've indicated 500 k temperature to the heated wall and to the other walls 300 k. my problem is that 1 can not boil the wather. the is no transfer. 1'm heaving all the parameters velocity and pressure correct but i can not see something there. please help. i really nead it.
did you knew how can i modelate this thanks cip
Old   August 9, 2004, 03:40
Default Re: urgent please heat transfer
ravi
hai friend, i read ur message , but i cant get ur problem, i cant understand ur problem- the way u explained it, b brief enough, ok, u have said that thetemp of the heated wall is 500k and other walls as 300k, wat is the profile of the walls? i cant get it, ok, reply soon, bye
Old   August 9, 2004, 15:15
Default thanks
cip_m
i've done it. thank's.
all the best. cip
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
heat transfer imbalance? URGENT ranton FLUENT 3 August 4, 2005 08:22
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
