August 6, 2004, 22:06 |
How to activate"spring-all-shapes"?
I am a fluent user, and using dynamic mesh to solve FSI problem.
the user-defined motion type was adopted based UDF. I found the spring-based mesh motion method did not work when structural mesh or mixed mesh with structural boundary layer mesh was used, so I want to activated the function"spring-all-shapes" through text command according to Fluent Guide. Fluent prompts:"By default, spring-based smoothing on non-triangular or non-tetrahedral cell zones are turned off. If you want to use spring-based smoothing on all cell shapes, you can turn on the model for these zones using the text-interface command spring-on-all-shapes? in the dynamic-mesh-menu." But the fllowing error occurs when I input the command "spring-on-all-shapes". /define/models/dynamic-mesh-controls> spring-on-all-shapes Error: eval: unbound variable Error Object: help How to solve this problem?Thanks |
September 1, 2004, 17:09 |
Re: How to activate"spring-all-shapes"?
There should be specific command to enable spring-smoothing for all shapes of mesh. Ask your local fluent engineer.
