scaling in Gambit. Please help!!
Old   August 6, 2004, 00:00
Default scaling in Gambit. Please help!!
Michelle
Hello, i am constructing my geometry in gambit, but the dimensions of the gasket i am using and my set up are really small, i.e in the order of 0.001mm. if i were to draw such a structure in gambit, it would be too tiny. does it matter , what dimensions i use, or if i scale everything by a factor of 100. what about my inlet flow rate, would i have to scale it too? How would all these affect my results?I would really appreciate any help.
Old   August 6, 2004, 00:01
Default Re: scaling in Gambit. Please help!!
Michelle
Old   August 6, 2004, 00:39
Dan Brzozowski
You can scale geometry in Fluent by going to the Grid/Scale... menu. So for example you could just take one gambit unit to be 1 micron. Then after you read the mesh into fluent, scale it by 10^6 in all dimensions.
-Dan
Old   August 6, 2004, 02:32
Oliver
That is right Dan but when you scale the grid, only the grid and not the physical value is scaled so if you have 10^-6m3/s as inlet flow rate you have to enter 10^-6. Such value involve convergence difficulties don't you think so?
Old   August 6, 2004, 03:11
Dan Brzozowski
I don't think there should be any convergence difficulties since Fluent uses scaled residuals to judge convergence (see User Guide section 24.16.1 "Monitoring Residuals").
If I understand this right, for an inlet flowrate of 10^-6m/s, the default convergence cirterion of 10^-3 would essentially require that the error not exceed 10^-9m/s. Here "error" is defined as some average of residuals from the continuity equation in each cell.
-Dan
Old   August 6, 2004, 12:34
Alex Chirokov
It is usually good practice to work with non-dimensional variables. But if so some reasons you want to work with dimensions choose units that are appropriate for your problem. Let say in 1 unit is 1um=1e-3mm. Ideally your geometry in gambit would extend from [-1 to 1] in order to minimize round off errors. Put origin in the middle of your model and choose units the give you maximum deviation from the origin less that 10. Note that you can scale your model as you please after you import it in fluent.
Good luck! Alex-
Old   August 9, 2004, 10:31
Default Thanks to Dan, oliver and Alex.
Michelle
Thanks to Dan, Alex and Oliver. your help is really appreciated.
Global scaling - grid independency testing Jenny CFX 6 December 10, 2013 03:52
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Scaling in Gambit. Jack Keays FLUENT 3 March 15, 2001 05:05
