August 9, 2004, 11:46 |
MeshCheck
Hi
how can i check in Gambit that the Mesh that i have made is correct.(before exporting the file in Fluent) thanx faiz |
August 9, 2004, 23:15 |
Re: MeshCheck
There isn't a uniform law for mesh quality,but you should ensure that the Equiangle Skew of your mesh should be low.Atually,to check the mesh is correct or not is concerned with your fundmental knowledge and experience .
August 10, 2004, 04:27 |
Re: MeshCheck
Actually, equiangle size and equiangle skew have to be lower than 0.95. I try to make meshs with parameters lower than 0.9. The more those parameters are high, the longer the convergence is.
Oliver |
