How to terminate fluent batch jobs?
We run fluent non-interactive on a Sun Gridengine by submitting our jobs batchwise and occasionally, we need to terminate a job. However, a simple termination kills the process without writting any of the results into a data file. Is there a simple way to terminate fluent and have a regular exit including the writting of a case and data file at the time of termination?
/Martin |
Re: How to terminate fluent batch jobs?
You can touch the file by touch /tmp/check-fluent and then rcp "casename" "username@workstationid". What I have to do after this is "ls" and it lists the case and data file at which iteration it was saved. I then I have to rcp that case and data using the same directory in which it gets saved into my home directory to be viewed in Fluent. After that you can kill the job. I hope this is understandable.
You can make it a little easier.
In your input file for the batch run insert a line including the parenthesis: (set! checkpoint/exit-filename "/directory/exit-fluent-####") Where directory is the directory you're storing your case and data files, and #### is some representative name. They say you can use "./" to indicate the directory where the case and data currently are, but that doesn't always work so well for me. And exit-fluent-#### can really be anything you want, but this is the format that works well for me. Then, when you want to stop the iterations and end the process, just type (this works for HP unix workstations at least): touch /directory/exit-fluent-#### It will save the case and data file after the current iteration, adding the iteration number to the file name, and the files will all be in the directory you specified in your input file. Hope this helps Jason |
I assume that set checkpoint/exit-filename "/directory/exit-fluent-#### should be placed in the shell script file that launches fluent and not in the journal file. Correct?
/Martin |
In the journal file.
Example: ;----------------------------------- ;Start of script ;----------------------------------- ; Set checkpoint - exit filename (set! checkpoint/exit-filename "/disk0/exit-fluent-2d-airfoil") ; Read Case and data rc /disk0/2d-airfoil.cas rd /disk0/2d-airfoil.dat ; Calculate 500 iterations it 500 ; Write Data wd /disk0/2d-airfoil-final.dat ; Exit file exit y ;----------------------------------- ;End of script ;----------------------------------- Then, whenever you want it to save the case and data and exit fluent, type: touch /disk0/exit-fluent-2d-airfoil In the directory "/disk0/" there will now be three new files (for example if you stopped at iteration 52): 2d-airfoil0052.cas, 2d-airfoil0052.dat, and another file that I believe ends in .inp The .inp file is supposed to be used to restart the processes, but I've never looked into it to see what it actually says. Hope this helps. Jason |
Thanks, I got everything I needed and it runs smooth in all the configurations that I use. Also when I tried to set the check-filename. Thanks again - Martin
