August 11, 2004, 03:06 |
3D post-processing
Hello. I was hoping that someone could help me?! I am running a 3D transonic wing and I need to plot pressure distributions over the wing at various span locations, BUT I can't find how to generate a plot of any specific z location (ie. I can only plot the results over the whole wing at once), and I have found that manually inputting data points is inaccurate. If anyone has any suggestions I would greatly appreciate it. Thanks, Natalie
August 11, 2004, 03:52 |
Re: 3D post-processing
Maybe you can creat some z-direction lines in Surface---Line/Rake panel and then plot the parameters you want in the XY-Plot panel with selecting these line for Surfaces.
August 11, 2004, 04:26 |
Use the Iso-surface function in the surface menu. This will enable you create surfaces of constant Grid--> z-coordinate from your wing surface. You can then use the xy-plot to plot the pressure distribution across the surfaces created. You can alsouse Iso-Clip to seperate the upper and lower surfaces of the wing.
Hope this helps Mark |
August 11, 2004, 05:13 |
Use a rake (and not line). In that way you can create any length with any number of points and get whatever results you need on that line (rake).
Ansys Post processing | ano999 | ANSYS | 1 | May 27, 2011 16:24 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 12:44 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
