initialize
Old   August 11, 2004, 14:04
Default initialize
Amir
Hi what is effect of clicking on APPLY button (in Initialize panel). I mean is neccesary click it? and another quastion : i cancel itreation (interrup itreation process) and i start itreation again. create it any problem in my results and solution process? Regards, Amir
Old   August 11, 2004, 14:27
Default Re: initialize
SAM
APPLY BUTTION WILL APPLY THE CURRENT CONDITIONS AND DISCARED THE OLD INITIAZE DATE, OTHER WISE UR SOLUTION WILL START WITH OLD ONE
THERE IS NO EFFECT ON SOLUTION ON STOPING AND RUNNING AGAIN
Old   August 12, 2004, 00:20
Amir
Hi yhank you very much. regards, Amir
why the inlet velocity magnitude differrent from the value i initialize? eyuhock FLUENT 26 April 20, 2015 21:34
initialize pressure gradient jiejie OpenFOAM 5 June 30, 2011 09:59
How to initialize a case file with udf? sima FLUENT 2 August 3, 2010 01:44
HELP Beginner ICEM initialize PRE-MESH parameters guest7777 CFX 2 October 18, 2007 06:18
Initialize error Vincent FLUENT 4 April 25, 2005 12:31
