Home > Forums > FLUENT
user-defined function hooks pannel
Old   August 11, 2004, 15:33
Default user-defined function hooks pannel
kevin
Anybody can explain what's the "Read/write Case Function" used for in the hooks pannel? it's better to give a example here, thanks.
Old   August 12, 2004, 12:33
Default Re: user-defined function hooks pannel
Alex Chirokov
Read/Write case UDF are for saving/loading you UDF specific data. For example your UDF uses some internal data in calculations, and these data can change during iterations. If you close your case these changes will be lost. I used it once for solving inductive coupled plasma in fluent (ICP plasma torch). Calculations of EM field depend on current in the coil which is changeable parameter. In order to save this parameter with the case I used Read/Write case UDF. So case will remember what current was used in calculations.
Old   August 12, 2004, 15:46
kevin
Thank you,Alex, then when will these UDF be invoked? at each iteration? And would you please clarify for me what's the difference betweeen read/write case and read/write data, it doesn't mention much in the manual. Thanks,
kevin
Old   August 12, 2004, 16:31
Alex Chirokov
They will be invoked at each Read/Write case/data event that you initiate from file menu in Fluent. you can put this line in your code to see what UDF is executed and to check whether it is executed at all.
Message("This is my Read/Write UDF Function number %d \n", 3);
Alex-
Old   August 12, 2004, 18:10
kevin
thank you so much, Alex
Thread Tools
Trackbacks are On
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
solving passive scalar by user function in AVLFIRE huyp Main CFD Forum 0 September 4, 2008 10:21
User defined function - CO level hari FLUENT 0 October 24, 2007 00:11
User defined function of mass flow rate Eric FLUENT 1 April 22, 2005 18:15
