-   -   Backflow occuring at a pressure outlet? (http://www.cfd-online.com/Forums/fluent/34388-backflow-occuring-pressure-outlet.html)
Dave August 12, 2004 05:05
Hi
I was wondering if anybody knew how I can stop backflow occuring at a pressure outlet? In my unsteady problem I have four ports that open one at a time and to simulate this I have a udf which changes the pressure at these pressure outlets. When a port is closed I set the pressure to be the same as the pressure inlet pressure as I do not know how to change the boundary condition to a wall. However, I get backflow from the "closed" ports which is completely messing up my results. How do I stop this from happening? Do I need to write a udf that changes the boundary condition from a pressure outlet to a wall and if so how do I do this?
Any help would be greatly appreciated. Dave
Zhihua August 12, 2004 17:39
Re: Backflow occuring at a pressure outlet?
I have never done simulations during which the boundary conditions are varied. I guess backflow appears because the interior pressure based on last calculation is lower than the inlet pressure in the flow direction. Seting the outlet pressure=inlet pressure means the outlet pressure is higher than the interior too. That's why backflow appears.
