Home > Forums > FLUENT
Fluent journal
Old   August 16, 2004, 03:56
Default Fluent journal
Can I write a more lisible journal in fluent than those is obtained by File/write/journal?
Old   September 11, 2004, 22:37
Default Re: Fluent journal - more lisible
Nick Chepurniy
Hi Oliver,
I do not have an answer. I have been asking myself the same question. I have searched the internet and found almost nothing. After three days I asked my self a question: Why do I need a more lisible journal ? If you do a Google search with the words: stanford fluent gambit - then the first two items will be: AUTOMATION and COMPUTATIONAL FLUID ... Get them printed out. For the second item the files are in .gz format - So what I do is select the file I want and when I am asked to open or save the .gz file I repond with CANCEL. Then I select the same file again and the second time the file is automatically unziped and you can save is in a readable format.
In these two references you will find examples of journal files in the format you and myself want !
But I have decided to stop looking for the nice format and just use the scheme format - it is ugly - but it does the job !
Old   September 12, 2004, 16:01
Nick Chepurniy
To get a more lisible journal file, on the Internet do a search using Google and search for:
"Fluent 5" ug disabled
Then in the "Fluent 5 User's Guide" manual read chapter 2, sections:
2.2 Text User Interface
In chapter 25 you will find the Reference Guide for each command and at the end of each command there will be a description of how to execute the same command using the text command format.
Start Fluent and in the Fluent window type:
this will give you a list of the aliases defined by the system. For example the file/read-case text command can be invoked using the alias rc defined as
(alias 'rc (labmda () (read-case)))
Summary: Text command can be placed into a journal file and using aliases can make the text commands even shorter.
Thread Tools
Trackbacks are On
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Fluent 12 Journal File Problem Krish FLUENT 2 July 16, 2010 06:10
running a journal file in Parallel FLUENT novice FLUENT 0 June 15, 2010 04:19
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
Problems With Journal When Writing Forces To File Andrew FLUENT 2 September 23, 2005 02:12
