gambit 2.1.6 and step file
Old   August 17, 2004, 13:19
Default gambit 2.1.6 and step file
Wenbin Song
The gambit 2.1.6 stopped working on one of my simple step files which contains two edges for an airfoil geometry, the step file worked fine with 2.0.4. Does anybody have any idea on any changes made to the Gambit?
Thanks
Wenbin
Old   August 20, 2004, 07:09
Default Re: gambit 2.1.6 and step file
Chief
Just a thought, if you have imported the step file into Gambit 2.1.6 fresh you may find that one of your two edges has been duplicated on top of one another. Go into 'delete edge' and read the yellow selection window as you click over the same line twice to see if another edge number appears. If it does, select the second one to appear and delete it. I have found that with complex 2D step imports this problem can cause wireframes to become unreadable files for no apparent reason. Perhaps someone else has had similar or can confirm / deny the above??
The Chief
Old   August 30, 2004, 21:40
patrick
I do have that problem with 3D, instead of 1 volume, it gives me 2 volume on top of each other. Just delete the similar features, it should solve your problem.
patrick
Old   August 31, 2004, 10:17
Chief
thanks for replying. It's good to know when you are not the only one!
Chief
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
problems with STEP file ertan FLUENT 0 August 1, 2008 17:51
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
