NMAKE COMMANDIN COMPILING
Hi, I have problem in compiling udfs.Making libudf is successful but I don't exactly know that how I must execute an nmake? If possible explain it for me.
Thanks and regards. svh |
Re: NMAKE COMMANDIN COMPILING
When Fluent was installed at your site there was a License Administrator and a Technical Contact assigned at the same time. Your Technical Contact has access to Fluents database where the nmake problem is explained.
Basically, you need nmake to be able to compile your UDF's. nmake is a utility similar to UNIX's make. |
Thank you very much for your response.Now I have another problem that I will be pleasant if you help me again .As you know in dynamic mesh for making some volume to move there are three methods ,in my case I have hex-cells so "spring smoothing" must be use but it dose not work.
I'm waiting for your useful comment. Thanks and regards. |
