-   -   how to set BC of cyclone separator outlet (http://www.cfd-online.com/Forums/fluent/34559-how-set-bc-cyclone-separator-outlet.html)
Lcw September 6, 2004 03:39
In simulation of cyclone separator, the BC of outlet is often defined as "pressure-outlet" or "outflow", which one is best for the case of closed operation? that is, the outlet of cyclone is linked with a centrifugal fan.
thanks
Lcw
fpingqian September 9, 2004 10:36
Re: how to set BC of cyclone separator outlet
When we don't know the outlet pressure, we can difine it as outflow.
Lcw September 10, 2004 09:25
If we define outlet as "outflow", the exit pipe of the cyclone model need to be prolonged, in general, how long does we choose the length of exit pipe? supposing cyclone cylinder diameter is 170mm, exit diameter is 85mm.
In fact, swirl flow must be 3-dimension, how much error beteen the 3-dimension swirl flow and the developed outflow?
thank you!
ap October 3, 2004 08:51
In my opinion you can get better results and a better convergence behaviour using the pressure outlet boundary condition.
Hi :)
ap
Lcw October 5, 2004 09:41
Thank you for response to my question, Downstream of my model is connected to a centrifugal wind machine, and can not use pressure outlet boundary condition.
arjun3020 February 22, 2012 02:40
Hi all,
how to define wall boundary conditions.
i think it is reflect.
and at inlet- velocity inlet
at outlet- pressure outlet.
but what about DPM tab in Boundary conditions. Trap, escape and reflect.
which conditions should i use at inlet and outlet?
