what is the relationship between inviscid model an |
September 5, 2004, 05:18 |
what is the relationship between inviscid model and euler equtions? if they are not the same, what is the difference? thanks for regards! charles
September 7, 2004, 04:55 |
Re: what is the relationship between inviscid mode
Hi; When you solve Euler equations, it means that you assume an inviscide fluid and neglect viscous terms in N.S. equations. So, if you choose inviscide option, you solve Euler equations. Regards ROOZBEH
September 8, 2004, 09:18 |
thank u so much
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 15:25 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
