Postprocessing
Old   September 30, 2004, 07:33
Default Postprocessing
joe
I am trying to get an output file over the coordinates positions (x,y,z) along a line on the surface of my model. Created a line and can plot/write (2D xy-plot), for example the pressure, along this line but would also like the coordinates of the surface to be able to draw the contours of the surface in for example Matlab.
How do I do this?
Best Regards Joe
Old   October 3, 2004, 06:47
Default Re: Postprocessing
Frasier Crane
I don't know how to do that in fluent but i know how to do that in matlab if you got a picture file (*.bmp, *jpg) with your information, check out the digitize2.m file in file exchage section under image processing from the mathworks website. I hope this helps!
FC
If you do it with fluent it will be easier.
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 09:55
How to export the specific heat and viscosity for postprocessing (compressible) ? david39 OpenFOAM Post-Processing 2 January 4, 2019 07:04
[pythonFlu] Postprocessing using pythonFlu + Matplotlib +Scipy francois OpenFOAM Community Contributions 2 June 21, 2011 11:26
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 16:17
postprocessing bas rijkse FLUENT 0 July 5, 2001 08:30
