Home > Forums > FLUENT
double precision and residuals
Old   September 7, 2004, 13:57
Default double precision and residuals
Mark Austin
I am running a simulation of a high temperature channel flow over a solid with the following characteristics:
+ Re = 37 + Energy Equation (without radiation) - heat generation in the solid and a convective boundary condition on the underside of the solid volume. + Species sources and sinks in the channel (CO2, CO, H2O, H2) + Temperature dependent gas properties like thermal conductivity, specific heat, etc. + The simulation is run using the double precision solver.
Everything seems to work well until the residuals seem to take an unexpected jump. With regards to residual asymptotes, the simulation looks like it is probably 75% complete, but then, these residual values spike and hold at levels that I believe were common for the same simulation run as a single precision.
Any ideas would help.
Thanks,
Mark
Thread Tools
Trackbacks are On
OpenFOAM goes multi-gpu Lukasz OpenFOAM 24 August 29, 2014 07:27
When to use double precision Mark Render Main CFD Forum 10 January 21, 2008 13:16
Precision in Fluent6 mitchoum22 FLUENT 1 August 12, 2005 05:25
Convergence problems - please help M Liddell FLUENT 3 February 8, 2005 20:06
