Home > Forums > FLUENT
B.C. for the interface between two volumes
Old   September 8, 2004, 07:29
Default B.C. for the interface between two volumes
Kim
Hello!
I have a question about setting the B.C.
How should I set the boundary condition between two volumes(for example solid-solid)? Each volume has its face at the interface. Is it enough to set B.C for one face or should I set for both faces? Or should I unite the two faces? (In my model it would be too much work --a)
I would like to know also for solid-fluid interface.
Thanks a lot your help!
Old   September 8, 2004, 07:58
Default Re: B.C. for the interface between two volumes
Ari
Hi Kim!
The choice varies according to the BCs features... try to specify them.
Ari
Old   September 8, 2004, 10:04
Kim
Hello, Ari! How are you? Nice to see you again. How is your work going? I read now UG chap.6 to understand for the setting of BCs. Really, there are many things to learn in FLUENT! When I have any question, can I ask you?
Old   September 9, 2004, 05:56
Ari
Welcome back Kim!!! My work is going on and I hope to be able to give you some useful advise. Ari
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
[GAMBIT] Connecting volumes makaero ANSYS Meshing & Geometry 4 April 15, 2010 19:18
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
