September 8, 2004, 18:43 |
nano fluids
hi all I want to know whether someone has used CFD to model fluids with nano particles and if he used fluent what models he used (Multiphases flow /discete phase model) thank you
September 10, 2004, 02:43 |
Re: nano fluids
I am modeling the flow of nanoparticles using the DPM model. If their volume in the fluid is less than 10%, then you should use this model. Otherwise, you should use the multiphase flow models. Lior. |
two mixing compresible fluids solver | ziemowitzima | OpenFOAM Running, Solving & CFD | 27 | August 13, 2020 12:40 |
nano fluif flow in openfoam | anijdon | OpenFOAM | 0 | February 18, 2011 16:22 |
radiation modell with two different fluids | discovolante | Main CFD Forum | 1 | April 26, 2009 16:05 |
Differents fluids separated by wall | phil | FLUENT | 0 | January 18, 2007 02:43 |
turbulent mixing of two fluids | ulrich bieder | Main CFD Forum | 2 | October 9, 1999 16:15 |
