how to solve isat problem in fluent?
Old   September 9, 2004, 08:55
Default how to solve isat problem in fluent?
yinyue
i am using fluent6.1 to solve combustion problem.when i use isat under EDC model,fluent gives me the error message: Error: isat_table_init: xscale must be positive; xscale = 0.000000e+00 Error Object: () what is it meaning? how can i solve the problem? thanks for your answer.
Old   September 9, 2004, 22:17
Default Re: how to solve isat problem in fluent?
cg
I think that this was a bug that occurs when the operating pressure was set to zero. I think that this has been fixed in the latest version of Fluent (6.1.22). What version are you using now?
Old   September 10, 2004, 08:48
yinyue
i am using 6.1.22 thank you for your answer have you some way to solve it?
Old   September 10, 2004, 09:01
yinyue
i change operating pressure to 12Pa, and FLUENT does not gives the error message. but i want to know whether it will do some harm to the result
Old   September 13, 2004, 09:10
cg
You can raise the operating pressure to 12Pa and then decrease your (initial) gauge pressure in the Solve -> Initialize panel by 12Pa. Please see the Fluent user guide.
Old   October 6, 2004, 13:48
Default how to solve combustiona problem
rajagopal
hello sir,
kindly need your help.
let me have a brief introduction. i am rajagopal doing final mechanical in bannari amman institute of technology, sathyamangalam.
i am learning the fluent in PSG technology, coimbatore.
i am analyzing the flame path and shape inside an bagasse fired combustion chamber of bannari amman cogeneration unit.
till date i have constructed the combustion chamber model in gambit and have meshed and exported it.
also just for sample purpose i have given air as input and checked the flow.
let me first describe the inlet points. there are 5 inlets for bagasse, 5 inlets for air justbelow the bagasse inlets to make the bagasse spread inside the combustion chamber . also air enters through undergrate which is the bottom portion oof the combustion chamber.
now my doubt is::
1. bagasse is not given in the materials list. so how to add it to the materials list.
2. i have created prepdf for bagasse. but the thing is that how can i think that bagasse will flow exactly in the inlet meant for it.
3.how could i differentiate the bagasse and air getting inside the comustion chamber.
even some more little doubts i have.
so sir if you could clarify these doubts, i could ensue my project.
and if u wish i can even send the works which we have performed till date.
awaiting for your valuale reply.
thanks in advance.
Old   October 13, 2004, 07:18
Default Re: how to solve combustiona problem
Karthick
Dear Rajagopal
I think u are solving the problem through non-premixed combustion model. In that you can add your oxidiser and fuel composition through pre-pdf
Regards Karthick
how to solve evaporation problem in fluent dkb_bg Main CFD Forum 2 September 30, 2011 00:06
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
Licensing problem with Fluent v5.5 moiami FLUENT 3 April 17, 2002 03:50
