September 9, 2004, 18:14 |
Zero Area Cells
Hi everybody!
I have a weird problem. I generated a model in Gambit, and when Fluent reads it, it reports there are cells that have zero area, and so the grid check fails, and i can't work on the model. I checked it, and although some of the cells are pretty small (deliberately!), it can't be said that they have zero area... Does anybody know what to do in this case? Is there any scaling needed to be done in Fluent, in order to correct it and make it read it properly? Thank you in advance! Lior. |
September 13, 2004, 05:18 |
Re: Zero Area Cells
OK. I found the error for the problem... I am using an axi-symmetric model, and by mistake i didn't define well a small zone in the wall as an axis, which caused the problems when exporting it to Fluent.
Thanks anyway... |
Display Modes | |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
