gas-solid flow in cyclone
Old   September 9, 2004, 23:26
Default gas-solid flow in cyclone
fpingqian
For the standardk-¦Åmodel each quantity ¦Õ the corresponding conservation equation of momentum or turbulence can be summarized in general form.
where ¦Õ can be ¦Å,k,u,the source term of gas and particle phase and so on. The source term can be defined when considering the interaction of particle-gas and particle-particle. However, I am not certain of whether I consider this in Discrete Particle Model when using Fluent 6.1 or not. On the other hand, if I use the Reynolds Stress Model to simulate the gas flow of cyclone, whether I can change the source term like the above? Your suggestions will be grateful for me. Thanks!
gas solid flow problem validation pandaba FLUENT 0 October 27, 2010 06:05
Simulation time for unsteady gas solid flow pandaba FLUENT 1 October 14, 2010 00:04
how to set up high temperature gas turbine flow simulation? adam2008 CFX 1 July 22, 2009 18:33
question about ideal gas thermal flow yong Main CFD Forum 0 January 6, 2006 23:58
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
