September 20, 2004, 15:03 |
moving wall and fluid
Hello
I'm using dynamic mesh to define a moving wall that is in touch with a fluid, I have used hex-cells so I can't use local remeshing , and I use layering and spring smoothing ,but when I preview the motion the wall moves and it makes fluid cells deformated,and creates negative volume. If possible help me to solve this problem. thanks svh |
September 30, 2004, 07:17 |
Re: moving wall and fluid
Hi, instead of using dynamic mesh you can do one thing. you craete your model as usual with out moving mesh and in Fluent you can specify that model as a movind boundary. Go to boundary conditions - selct wall - set - and selct momentum -- and there you can find moivng wall, select it and it will ask velocity of the moving wall, and you can give the velocity value according to your problem. Try with this one and after that you can jump to the problem what you are doing. I hope it will work, some of our friends are validating this problem by this method only
Venu Gopal |
September 30, 2004, 07:33 |
Thank you but in my case there is a pipe that oscillates and I have to use Dynamic mesh.I must active spring smoothing method but still I've not been successful.
I'm waiting for your useful comment. Thanks. |
Display Modes | |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
modelise the motion of the fluid by a moving wall | samnetmoon | FLUENT | 1 | April 21, 2008 07:06 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
moving wall and fluid | soody | FLUENT | 3 | September 20, 2004 01:37 |
