Switch problem! using 2 custom udf laws at the same time
Old   September 15, 2004, 10:48
Default Switch problem! using 2 custom udf laws at the same time
HP
Hi! I have written 2 custom udf laws (one for devolatilization and one for surface combustion). When I hook my custom devol law instead of Fluent's one, everything works fine. Similarly when I hook my surf combustion law (instead of Fluent's standard), but when I hook them both simultaneously, then surface combustion does not occur.
Can anybody tell me what the problem is? Is it a switching problem? Any suggestions would be appreciated.
Thanks in advance Ilias.
The laws are:
#include "udf.h" #define PI 3.14159265358979323
boolean just_started_dev_law=1; boolean just_started_cc_law=1;
/************************************************** ******************** constant diameter law for devolatilisation ************************************************** *********************/
DEFINE_DPM_LAW(devol_const_diam_law, p, ci) {
static real dp_law_init;
//Get particle state when law starts
if(just_started_dev_law){
dp_law_init=P_DIAM(p);
just_started_dev_law=0;
//first, call standard devolatilization routine to calculate
//the mass and heat transfer
DevolatilizationLaw(p);
//then set the current diameter (constant during the devolatilisation
//procedure) equal to the after drying diameter
P_DIAM(p)=dp_law_init;
//calculate and set the current density (according to the
//constant diameter)
//rho=m/V
P_RHO(p)=P_MASS(p)/(PI*dp_law_init*dp_law_init*dp_law_init/6);
/************************************************** ******************** constant density law for char combustion ************************************************** *********************/
DEFINE_DPM_LAW(char_comb_const_diam_law, p, ci) {
static real rhop_law_init;
if(just_started_cc_law){
rhop_law_init=P_RHO(p);
just_started_cc_law=0;
//first, call standard char combustion routine to calculate
SurfaceCombustionLaw(p);
//then set the current density (constant during the char combustion
//procedure) equal to the after devolatilisation density
P_RHO(p)=rhop_law_init;
//calculate and set the current diameter (according to the
//constant density)
//dp=f(rho,m)=(6m/rho/pi)^0.333
P_DIAM(p)=pow(6*P_MASS(p)/(PI*rhop_law_init),0.3333333333); }
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Problem in UDF time dependent vloumetric heat source eng_yasser_2020 Fluent UDF and Scheme Programming 0 March 30, 2014 09:07
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 16:24
