September 19, 2004, 10:41 |
2-phase surface flow
Hi! Does anybody knows any other models to handle surface flows except VOF? I see in Eulerian and Langrange model, that i have to put a characteristic diameter in the secondary flow panel, which means that i have to describe particle flow, which i don't want. The reason for asking is that Fluent reports that Dynamic mesh and VOF are not compatible!(i use dynamic). Any ideas are welcome! thanks!
September 20, 2004, 04:11 |
Re: 2-phase surface flow
"The reason for asking is that Fluent reports that Dynamic mesh and VOF are not compatible!"
Where does Fluent report this? In our cases it is compatible. Frank |
September 20, 2004, 11:24 |
Thank you Frank !!I wanted this confirmation!!!! But take a look in Fluent 6.1 Documentation:FLUENT Model Compatibility, and you will see what i mean! i hope that the results of dynamic vof are certainly reliable!
September 21, 2004, 03:19 |
Hello stk,
this is a mistake of Fluent, which was also confirmed by FLUENT support. Frank |
Display Modes | |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 08:58 |
two phase flow + ice phase and breaking | soeren87 | OpenFOAM Running, Solving & CFD | 0 | September 19, 2010 11:20 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 03:52 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 09:10 |
Two phase Flow | Ashok | Main CFD Forum | 0 | February 14, 2004 07:37 |
