SI engine combustion
Old   September 2, 2004, 02:43
Default SI engine combustion
torn
Have anyone known did Fluent can be solve combustion in spark ignition engines? and Which combustion model can be apply (such as partially premixed or EBC) ?
Torn
Old   September 21, 2004, 11:57
Default Re: SI engine combustion
chidananda
i would like to have information about combustin in si engines
Old   September 21, 2004, 22:57
torn
I model with premix combustion with deforming mesh. The fuel is CH4. When I use 1 step finite rate/eddy-dissipation, after patch Temperature and all product species, the combustion does not occur. The flame was terminated, it not propagate.
Moreover, I try with EDC and Partially premix combustion.
When use Partially premix model, I thing it not possible because Pre-Pdf in fluent cannot vary with pressure. In this situation, the pressure not change all the time even if the cylinder was compress by piston.
With EDC the results as same as finite rate/eddy-dissipation model. Maybe EDC is appropriate with CI combustion only.
So, chidananda, If u have other experience with fluent combustion please tell me.
Torn
Liquid rocket engine non-premixed combustion model Erik FLUENT 2 November 28, 2013 14:09
Diesel Engine combustion chamber analysis sachinthakre FLUENT 12 August 13, 2013 14:14
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) kelvinlim Main CFD Forum 2 January 26, 2012 22:19
Diesel Engine Combustion Analysis fluidsuser FLUENT 0 December 1, 2010 21:29
combustion in internal combustion engine George Main CFD Forum 0 September 7, 2006 14:41
