September 22, 2004, 08:19 |
How to active "Spring-Based Smoothing "?
I'm using dynamic mesh to make a moving pipe ,the wall is defined as a rigid body ,the cells are hexahedral ,and I have used symmetry BC.
In previewing the motion just the wall moves and fluid interior cells get deformated and it creates negative volumes. I have used bellow command to turn on the Spring-Based Smoothing method: > (rpsetvar 'dynamesh/spring/all-element-type? #t) dynamesh/spring/all-element-type? > but nothing changed. Maybe the settings that I put in dynamic parameters panel aren't correct , please please help me to solve this problem. Thank you in advance. svh |
incorrect temperature in pressure based solution | Kian | FLUENT | 1 | July 6, 2009 05:59 |
arc based TFI smoothing? | zonexo | Main CFD Forum | 0 | August 20, 2006 22:00 |
Hexa smoothing (ICEM CFD 10.0) | CFDworker | CFX | 3 | November 2, 2005 10:23 |
Help me to active Spring Based Smoothing!!! | Atefeh | FLUENT | 0 | September 29, 2004 15:32 |
How can I active spring Based Smoothing?? | svh | FLUENT | 0 | September 26, 2004 14:13 |
