How to active "Spring-Based Smoothing "?
I'm using dynamic mesh to make a moving pipe ,the wall is defined as a rigid body ,the cells are hexahedral ,and I have used symmetry BC.
In previewing the motion just the wall moves and fluid interior cells get deformated and it creates negative volumes. I have used bellow command to turn on the Spring-Based Smoothing method: > (rpsetvar 'dynamesh/spring/all-element-type? #t) dynamesh/spring/all-element-type? > but nothing changed. Maybe the settings that I put in dynamic parameters panel aren't correct , please please help me to solve this problem. Thank you in advance. svh |
