May 23, 2006, 19:08 |
help using porous jump
hi all,
i need to create a thin membrane inside a volume and give the porous jump condition. but whenever i create a face inside a volume and specify the porous jump boundary condition and export it to fluent, the face disappears and everything is taken as interior. how can create and specify a face in the interior and specify it as porous jump? thank you very much in advance |
May 24, 2006, 11:27 |
Re: help using porous jump
Porous jump in fluent is a particular condition applied to a interior face of fluid. If you have problems importing your model from gambit, try to assign a different condition to your porous face in mesh, than, after importing in fluent, try to apply your porous contition in \boundary contition menu. I hope it's helpful. regards.
Adriano |
May 25, 2006, 00:58 |
thank you Adriano, i did try this quite a few times for other boundaries. but for this porous jump problem, the face needs to be double sided interior as per the manual. even if i change it to any other type of boundary condition, any face inside the fluid zone is not recognised by fluent except as an interior.
May 25, 2006, 04:01 |
In this case it's maybe necessary to use a UDF such DEFINE_PROFILE or samething similar. U must apply your condition only on face side interessed with a face loop or similar. Adriano
September 5, 2013, 12:27 |
double sides thin membrane
moon
Rep Power: 14 |
I woul like to set velocity and concentration in both sides of a thin membrane in fluent ,but i cant ,because the porous jump panel had not place where we can put theses condition , is it a sujestion ?
[ICEM] How can I define different zones in ICEM? | llrr | ANSYS Meshing & Geometry | 14 | February 12, 2017 13:44 |
[Commercial meshers] Porous Jump creation problem | mulfal | OpenFOAM Meshing & Mesh Conversion | 4 | December 9, 2013 11:59 |
Porous jump in urban environment | samygero | FLUENT | 0 | February 14, 2011 18:26 |
Porous Jump | Naresh | FLUENT | 0 | April 25, 2007 15:36 |
Testing the integrity of POROUS media and por jump | Azman | FLUENT | 0 | July 31, 2006 11:11 |
