User defined memory
Old   September 24, 2004, 00:10
Default User defined memory
Hp
I have some problem in using UDM. I am using a multiphase model and I need the user defined memory to save the velocity. The following is my code:
#include "udf.h" DEFINE_ON_DEMAND(Init_UDM) {
Domain *mix_d=Get_Domain(1);
Thread *t,*water_t;
cell_t c;
real t1;
thread_loop_c(t,mix_d)
begin_c_loop(c,t)
water_t=THREAD_SUB_THREADt,0);
C_UDMI(c,t,0)=C_U(c,water_t);
}end_c_loop(c,t)
I first define the 1 user defined memory and then execute the Excute_on_demand. And I get the following error information. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
I am so confused since I can't find anyting wrong with the code. Can someone clarify for me? Thank you.
Hp
Trouble setting user scalar and user memory names tstorm FLUENT 6 November 23, 2022 03:58
How can I allocate user defined memory? MASOUD Fluent UDF and Scheme Programming 1 November 20, 2014 02:12
user defined sourcen term xck1986 CFX 1 July 8, 2010 08:35
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 05:29
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 09:19
