Choice of turbulent models for jet impingement |
September 27, 2004, 17:56 |
I am currently working on submerged jet impingement cooling using the K-Epsilon "realizable" and K-Omega models. Could you give me the values of the wall Y+ that I should use with both these models? Thanks in advance for any suggestions. Akash |
September 28, 2004, 02:58 |
Re: Choice of turbulent models for jet impingement
Would suggest starting with the one equation model, Spallart Allmaras. y+ vaues near 1, or over 30. check with the skin friction coefficient results from literature. that should give you a starting point.
Query: is this a supersonic jet impingment study that you are conducting? cheers Nandu |
September 28, 2004, 12:23 |
Hi Nandu,
Thanks for your input. I am modelling subsonic jet impingement. I tried the Spallat Allmaras model but my problem requires refinement near the wall and hence the need for enhanced treatment near the walls. This option is provided by the K-epsilon model and that is why I chose this model. Thanks, Akash |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Laminar doesn't converge; Turbulent models do? | Amit | FLUENT | 11 | April 23, 2015 22:55 |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 21:31 |
Reynolds transport, turbulence model, etc | Beginner | Main CFD Forum | 1 | January 7, 2009 05:36 |
