Aircraft dynamic stability derivatives
Old   September 1, 2004, 12:21
Default Aircraft dynamic stability derivatives
Jon
Hi Guys
I am currently using Fluent to compute an aircraft flow field. May i ask how do you use fluent to get estimates for the dynamic stability derivatives for an aircraft?
Regards JOn
Old   September 8, 2004, 20:01
Default Re: Aircraft dynamic stability derivatives
David Stanbridge
You are going into new grounds since Fluent is not reknwned for its aerodynamic accuracy. You are more likely to get better results from other CFD packages, i.e CFX.
Dave
Old   September 8, 2004, 22:13
Jonathan
Hi but i just wish to do a rough approximation on the dervatives. is there any way in fluent do it? Thanks!
Old   October 1, 2004, 01:57
Default Porous jump modelling
Alastair Walsh
I am trying to model a Mach 2 flow across a 6% open area perforated plate in 2-D FLUENT but am having trouble with the permeability, porous medium thickness and the pressure jump co-efficient, any ideas on how to approach this or what values i should be using would be greatly appreciated
Aerodynamic Stability Derivatives Andrew Clark FLUENT 1 November 23, 2021 20:19
Stability Derivatives embolado FLUENT 0 December 27, 2010 01:12
fluent for stability derivatives....?!?! naomi FLUENT 0 August 10, 2007 01:02
numerical stability due to cross derivatives wen long Main CFD Forum 2 September 12, 2005 02:10
Stability derivatives evaluation Daniel Dekel Main CFD Forum 0 June 26, 2002 08:28
