Re; heat transfering
Old   September 23, 2004, 22:47
Default Re; heat transfering
Benny
Hi all,
I want to know if FLUENT has the capabilities to handle with the heat tranfering between solid (stainless steel) and water? Thank you!
Best regards!
Benny
Old   October 4, 2004, 11:54
Default Re: Re; heat transfering
venu gopal
You can do lot of heat transfer simulations by using Fluent. You can do almost all heat transfer problems in heat transfer. Some radiation cases will not work with fluent. To get an idea you go through the Fluent user guide and tutorial manuals.
Venu Gopal
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
can STAR-CD simulate a solid transfering heat ? lenson Siemens 6 December 30, 2005 03:13
heat transfering between solid and fluid Benny FLUENT 4 November 15, 2004 19:20
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
