October 3, 2004, 22:52 |
Drop velocity ??? help me !! -.-
Hi...
I am testing the model that the liquid is falling down on the surface. VOF - 2 Phases (air, water) - Geo reconstruction - unsteady And I made the volume fraction for the liquid. :> adapt - region - circle :> initilize - patch I would like to put the velocity condition, 1.6m/s, for the liquid. But, I dont know how to put the initial velocity for the liquid. Should I use the UDF ? Is there any good way to solve the problem, not using UDF? Please, help me. Thanks for your attention Jay |
October 5, 2004, 00:45 |
Re: Drop velocity ??? help me !! -.-
hi Jay,
When you patch the region, there is an option where you can specify the initial pressure, velocities and temperature(if you have enabled the energy equation! just like you patch region for volume fraction by choosing 1 for water, you can specify velocity, pressure etc by choosing mixture! and since you are simulating water dropping, dont forget to enable gravity! hope this helps. Aravind |
October 5, 2004, 01:19 |
^^;; Thanks
Hi Aravind
I found the way you just told me. Thanks for your attention. Have a nice day.. Jay |
Display Modes | |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 20:08 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 09:42 |
Pressure Drop in terms of velocity | Arun | FLUENT | 0 | June 26, 2008 08:45 |
Relationship between velocity and pressure drop | harry | Main CFD Forum | 13 | May 8, 2007 07:39 |
