Gambit Boundary Edge Problems
I am using Gambit 2.0.1 to generate very simple solid geometry (a cube) with boundary zones and export it to a standard Gambit Neutral Format text file. I am using the generic solver. I am having difficulty with assigning (or not assigning) boundary properties to edges: I first create a group containing one face only (specifically telling Gambit not to include any edges or vertices attached to this face). I then specify a boundary type (NODE) using this zone as the entity. When I output the information to a neutral file, Gambit has included all of the nodes attached to the face AND the lower geometry in this boundary. I want the edges excluded from the boundary. Can anyone help me with what I am doing wrong? The case I am using to test this is a simple cube. I get the same problem if I skip the zone step and directly apply the boundary type to the face (excluding the lower geometry). Thanks in advance, Ashton Peters P.S. I am also having problems the same as those described here (http://www.cfd-online.com/Forum/flue...cgi?read=13403). I have checked my geometry, but the problem remains. |
