patch /initialize value setting
Old   October 6, 2004, 06:39
Default patch /initialize value setting
Sam
I am working with mixture pattern of two gasses (80 %Ar and 20 % N2) in side a vacuum chamber.
*Is any way to set both N2 and Ar fraction zero before starting solution? When I want to patch /initialize species transport model, i saw only one element in the list. So, if i set N2=1 or 0.5 etc then Ar value set automatically 0, or 0.5 etc respectively. And after a lengthy iteration time, i got almost same value (as set at initial value) all over the domains regardless what the value of velocity i set at inlet boundary. As N2 is only 20 %, it mass fraction should be very low all over the domain...
May be Ar penetration rate inside N2 is very slow (I am not sure).I do not know how many days i need to run solution for getting equilibrium result over whole domain!!!!!!
Waiting for your kind reply Regards, sam
Old   October 20, 2004, 06:51
Default Re: patch /initialize value setting
cuihu
I have the same problem.Who can help us?
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
