Merging volumes created from imported point clouds
Old   October 6, 2004, 09:42
Default Merging volumes created from imported point clouds
Nicklas Törnblom
Hello.
I'm in the process of creating one single volume from two separate ones. I've imported two clouds of points (X-, Y- and Z-coordinates) disguised as ICEM-data into GAMBIT. GAMBIT automatically creates two tube shaped faces which I would like to merge so as to create one single, bifurcated tube.
Has anyone any idea on how to do this?
Thanks in advance.
Old   October 23, 2004, 02:15
Default Re: Merging volumes created from imported point cl
Kiran
Try merging the edges before u create faces.then try to merge the faces.Hope it helps!!!
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
from point clouds to surface/volume waters Main CFD Forum 1 February 5, 2011 10:16
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Alternate method to subtracting volumes? Daniel Lee FLUENT 2 July 25, 2005 09:58
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
