Cell surface
Old   October 22, 2004, 08:31
Default Cell surface
David
hi,
I am at present writing a UDF. I know if I want to get the cell volume i have to write C_VOLUME(c,t) but there is no definition on how to get the cell area.
Does anyone know how to handle this?
thank you very much for your time
David
Old   October 22, 2004, 08:46
Default Re: Cell surface
dieter
You can try taking the sum of all face area's (command F_AREA(A,f,tf)) within a cell. You can do this in a loop over all faces in the cell.
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
Export Cell Surface Area Thierros CFX 0 April 28, 2010 06:01
call parameter that store surface area of cell tipakorn Siemens 0 October 3, 2006 23:12
Normal vector on cell surface? Ethan Siemens 0 November 2, 2004 09:42
Beginner: cell faces of surface cells Sunlight007 Siemens 0 August 24, 2003 17:19
