October 20, 2004, 09:24 |
DPM UDF
hi,
and thanks for your time in reading and replying to my request. I would like to know whether there is any possibility to know the number of particles that cross a cell in order to get the number density? I'm trying to write a udf but if anyone can help, i would truly appreciate it. thanks Regards David |
November 16, 2004, 14:56 |
Re: DPM UDF
I don't know the direct answer of your question but, you can use a macro C_STORAGE_R(cell,t,SV_DPMS_MASS), that stores the particle mass in each cell. If you are using monosize particles, then you can very easily get number density of particles.
Hope this helps. |
November 16, 2004, 14:59 |
Re: DPM UDF
thanks Umesh,
I will try that. thanks again David |
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT | subhankar_bhandari | FLUENT | 0 | August 19, 2010 03:01 |
please help me. i have question about the UDF at the DPM | motallebi | FLUENT | 0 | July 6, 2009 11:27 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
DPM with UDF - Step-by-Step Procedure???? | Prashanth | FLUENT | 3 | April 3, 2009 17:45 |
DPM - UDF for fluctuating bubble size | Jaroslav Kotara | FLUENT | 1 | April 19, 2006 09:02 |
