FLUENT scheme language
Hi! I'd like to learn more about using the Scheme language with Fluent in the journal file. Unfortunately the Fluent user's guide does not contain all the command I could use. I learnt a little of Scheme but the problem is: how can I use at the same time scheme command (do cicle, if condition ecc...) and Fluent commands (read-case, no of iteration ecc...). If I use Fluent command within a do-loop written in Scheme, Fluent does not recognize its commands! I hope to be clear Please help me! Luca
Re: FLUENT scheme language
Maybe this short manual will help you. But it is written in German.
fluid.jku.at/staff/javurek/Fluent/scheme.pdf |
Thank you Karl for answering. i got that guide and actually i solved my problem with the (ti-load-string) function. Thank you again. Luca
